Example Code
Signal Express Decimated Data Removal Using LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This VI removes groups of decimated data from TDMS files, added by NI SignalExpress, this data is only used by SignalExpress for display purposes, and so isn't neccessary in other applications (like DIAdem). This VI was created as people appeared to be having trouble using the plugin that exists for this.
Description
This VI opens and reads a TDMS file saved from SignalExpress. All groups with the word "Decimated" in the name will be removed, and then either the file will be replaced, or a new file created, as chosen by the user. It works by searching for the word decimated and not including this in the data that is re-saved
Requirements
  • LabVIEW 2013 (or compatible)
  1. Open VI
  2. Select mode dependent on requirements, either create a new file that will have the correct formatting, or replace the existing file with the newly sorted data
  3. Specify the path of the original file
  4. If you are creating a new file, specify the path of the file to be created.
  5. Run the VI
Additional Information or References
VI Block Diagram
Matt H
National Instruments UK
