Example Code
Signal to Square Wave Converter Using LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
 Overview
This example shows one way to convert an input signal into a square wave of arbitrary amplitude.
Description
This example shows one way to convert an input signal into a square wave of arbitrary amplitude.  The VI takes an input signal, filters it to get the desired frequency components, then amplifies the signal greatly so that it can then be clipped into a square wave.  The example assumes that the measured signal does not have a DC offset or that the DC offset is removed during filtering.  An offset can be applied to the signal after filtering but before scaling to change the duty cycle of the resulting square wave if desired.  The program assumes that the input signal is an array of doubles.
Requirements
LabVIEW Full System Development 2012 or compatible, LabVIEW Advanced Signal Processing Toolkit
  1. Enter the Input Original Signal parameters (Number of samples, Amplitude, Frequency
  2. Enter the filter parameters for the incoming signal (fs, fh, fl, order)
  3. Enter the Upper and Lower limits for the desired Output Square Wave
  4. Run the VI
Additional Information or References
VI Front Panel
VI Block Diagram
**This document has been updated to meet the current required format for the NI Code Exchange. **
Comments
Todd S.
NI Employee (retired)
on
Doesn't look like the attachment is showing up...
Todd S.
LabVIEW Community Manager
Burt_S
on
Thanks Todd.Fixed it!
BigBri
Member
Member
on
Why not pass the original signal array through the 'Sign' function to get a unit amplitude square wave then scale it to the amplitude you need? Much less code required.
