Example Code
Simple Alarm Clock
Code and Documents
Overview
Alarm Clock that displays the time and beeps when the alarm is on.
Description
Simple VI programmed to work as an Alarm Clock, implemented by a state machine design pattern.
  1. Run the application
  2. If you want to set the alarm, press the 'Se Alarm' button.
  3. Enter the 'Hour' and 'Minute' for the alarm settings.
  4. When the alarm is on, a 'Beep' sound will continusouly be on.
  5. Press the 'Stop Alarm' to stop it.
  6. Press the 'Stop' button to terminate the application.
Requirements
Software
LV 2013 or higher
Additional Images (Front Panel)
Additional Images (VI Snippet)
Contributors
