Example Code
Simple Event Structure With a Filter Event Using LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Description
Overview
The purpose of the code is to demonstrate Filter Events using a stop button that triggers an event in LabVIEW.
Description
When you run the application it is waiting for the stop button to trigger an event. When the stop button is clicked before the Stop Button Notify event case runs the Filter case will run. In the Filter event case, it asks the user if they really want to stop the program. If the user selects No the event structure will ignore the Stop Button Notifier event and exit the event structure to wait for another event or complete other tasks outside the event structure in the while loop. However, if the user does select to stop the program from the dialog it will run the Stop Button Notifier Event and stop the program. Therefore the Notify Event Case will never run without first running the Filter Event if one exists. For more information, refer to Notify and Filter Events.
Requirements
  • LabVIEW 2012 (or compatible)
  1. Run the VI
  2. Click the Stop Button
  3. A Dialog should appear because of the Stop Filter Event
  4. If you select No you should then see the number of iterations increment
  5. If you select Yes you should then see the number of iterations and the Number of Times the Stop Button Case increment
Additional Information or References
VI Snippet
M. Whitaker
ni.com/support
