Overview
This VI is meant to serve as a tutorial for learning the basics of LabVIEW Real-Time FIFOs (RT FIFOs).
Description
FIFO stands for First In First Out, and is similar to a queue. RT FIFOs are meant to be used for communicating data between a time critical thread and lower priority threads without harming determinism (as in the case of using queues, notifiers, and global variables). This method should be used to transfer data safely from a time-critical loop (thread) to a communication loop (thread) running at normal priority, which can then be used to transfer the data to the host machine without affecting the system determinism.This is just an example of how the functions that come with the LabVIEW Real-Time Module can be used.
Requirements
Software
Hardware
Additional Information or References
