Overview
This VI simulate Sudoku game by stored puzzles.
Description
As a new intern at NI, and completely new to LabVIEW, I took a 3.5 day LabVIEW training course. On the last day, we had the opportunity to use what we had learned to make an application of our choice. I chose to make a Sudoku game. Nothing too complicated, and so far it only has three stored puzzles: 1 Easy, 1 Medium, 1 Hard. Each level of difficulty has its own VI, and the solution for that level is hardcoded into the block diagram. On the front panel, the user can enter a number in each slot. If the number entered matches that of the solution, the block is bordered in green. Otherwise, the block is bordered in red. The user can choose to restart the puzzle, which returns all number blocks to their original value.
Requirements
Software:
1. Run the VI.
2. Select Difficulties and start playing.
Additional Information or Resources
*UPDATE*
6/22/2010: I have uploaded the project as a Zip file. Download the Zip file. Feel free to explore the source code. The main VI is Sudoku.vi. You can run that and then choose the difficulty to play.
Or you can download Sudoku.exe and simply run it to play the game. To run the .exe, you only need the LabVIEW Run-time Engine (free download)
Description-Separate-2Example code from the Example Code Exchange in the NI Community is licensed with the MIT license.
Hey Framran!! This sounds like an awesome app. However, I am unable to open it. Was it saved in a beta version of LabVIEW?
If you could repost the apps in a previous version, you would make the community very happy!
Thanks! ![]()
There is an 88 instead of 8 in Medium.vi, string 6 7.
