Overview
This simple utility shows or hides a front panel whenever I launch a subVI dialog. There are two VIs of interest: Show VI.vi and Hide VI.vi.
Description
I've been posting a lot of XControls to this forum, so I thought I'd take a step back and post some simple code that users can use without having LabVIEW 8!I use this simple utility all the time to show or hide a front panel whenever I launch a subVI dialog. There are two VIs of interest: Show VI.vi and Hide VI.vi. Just drop them into a VI to show or hide it respectively.Pretty easy to use. The subVIs only have error in and error out terminals. They come with a small example two of how to implement them. Change control: Merged Show VI.vi and Hide VI.vi into one VI that uses an enum to set the Front Panel state to whatever the user chooses (Hidden, Standard, Minimized, etc). The original Show VI and Hide VIs are still in the llb. The new VI is called Set FP State.vi.
Requirements
Software
LabVIEW 2012 (or compatible)
Additional Information or References
Block Diagram
Improvment Idea
It might be better to have one VI where the user can wire in an enum to set the visible state (this will allow more than just hidden and standard) - maybe even add an enum item to return the FP to its' previous state...
Re: Improvement Idea
I agree with this idea. I think originally I wanted the code to be as small as possible on the BD. But I implemented your idea for maximum flexibility. Having a return to previous enum would require keeping track of which VIs were in what state, since this non-reentrant subVI could be called from multiple locations. This adds unnecessary (if convenient) overhead to the program.
