Description
This VI will calculate the Rollet's stability factor (K-factor) from a set of four s-parameters in dB - angle format.
K-factor that is greater than one tells you that your amplifier is unconditionally stable. If K is less than 1, you may have a problem.
Requirements
LabView 2012
k_facror.vi
dB Angle to Complex.vi (sub-VI used by k_factor.vi)
