Overview
This VI shows how to perform a software-based retriggerable analog input acquisition using the DAQmx Control Task.vi.
Description
Older E and M series cards do not have built in retriggerable analog input. One workaround we can implement is to have a finite analog input task that we can then start, wait for the trigger, acquire data, and then stop and restart to wait for the next trigger. This is a costly process, but we can increase the programming efficiency by using the DAQmx task state model to our advantage. By default, the DAQmx task state model starts in the unverified stage and then moves through the verified, reserved, and committed state before going to the running state where we take our measurements. The Start Task VI will move us from the unverified state to the running state and the Stop Task VI will move us back to the unverified state.
However, by using the DAQmx Control Task VI we can get our task to the commit state, before starting the task. The task will then move back and forth between the commit and running state instead of between the unverified and the running state. This will increase the efficiency of our loop and will allow us to retrigger at a faster (albeit slower compared to hardware retriggering) rate.
Requirements
Software:
Hardware:
Additional Information or References
VI Snippet
