Overview
This example shows how to sort a multicolumn listbox by simply clicking the column header. These are modifications of code written by user LaRisa_S (Her code is located here: MCL Sorting).
Description
This example is designed to allow the user to sort a multicolumn listbox by any of the columns just by clicking the header. The main VI uses the subVI to sort the multicolumn listbox. As seen in the main VI, to use this, the user will drop the MCL Sort By Column.vi on to the block diagram, and use an event structure to fire on the event of the user's mouse coming up while on the listbox. The MCL Sort By Column.vi will receive a reference to the listbox, and will then sort the elements either ascending or descending (based on the last click).
Requirements
Additional Information or References
VI Front Panel
VI Block Diagram
