Example Code
Split 2D array
Code and Documents
Overview
This example demonstrate the use of Index Array functions to split a 2D array at a specified index.
Description
This VI receives a 2D array of strings and splits it into an Upper and an Lower array. The split happens at the row index specified. The index can be simply changed at the front panel.
Requirements
  • LabVIEW 2012 (or compatible)
  1. Open the VI "Split 2D Array 2012 NIVerified.vi”
  2. Run the program
Additional Information or References
VI Snippet
Comments
advance_chintan
Member
Member
on
its not spliting this kind of arrays...
https://decibel.ni.com/content/servlet/JiveServlet/showImage/105-31287-118956/New+Bitmap+Image.bmp
ANY suggestions??
goldmouse72
Member
Member
on
Not sure I understand what you mean about not being able to split those kind of arrays. Please see image.
Do you have your array on a .txt file and then extracting the strings to populate the array control?Capture.PNG
focus
Member
Member
on
An alternative (maybe simpler) for the same purpose.
TimsTools
Member
Member
on
This VI does exactly what it needed to.  Good candidate for the LabVIEW native palet.
goldmouse72
Member
Member
on
Cool
Wouldn't that be awesome?
