Example Code
Square Wave with Variable Duty Cycle in LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This VI exemplifies how to create a square wave which parameters could be modified during runtime.
Description
This code uses the Simulate Signal Express VI and it could be easily used for simulating the behavior of hardware for testing purposes.
The parameters that could be changed are the Offset, Duty Cycle (%), Amplitude, Phase, and Frequency. The waveform chart has the autoscale feature on both axes.
Requirements
LabVIEW Base Development System.
1. Open the attached VI named “Configurable Square Wave LV 2012 - NI Verified.vi”.
2. Run the VI.
3. Change the square characteristics as desired.
Additional Information or References
Will
CLA, CLED, CTD, Former CPI
LabVIEW Champion
Choose Movement Consulting
choose-mc.com
