Example Code
Stream Data Exchange
Products and Environment
    Software
  • LabVIEW
Code and Documents
Description
These two VIs show the speed of the exchange of multiple data in different formats (float, boolean, string) through stream over TCP/IP.
How to Use
Open the two provided VIs, VI-1 and VI-2. Run them, and remember that the first to run must be the first to stop.
Active/Deactivate the digital buttons in both VIs, write data string on the table from VI-1 and see how speed behaves.
Related Links
String Table Modbus TCP - NI Community
See the speed of the VI in the link provided before to compare the amount of data and transmission / reception speed against the sample "stream".
Contributors
