Overview
The example demonstrates how you can manipulate arrays by moving the first column of a 2D array, to the end.
Description
The user inputs a string which is then converted into a 2D array of boolean values. This is then shown as a moving message on the front panel. To achieve this, the array is manipulated by moving the first column to the end every iteration until the code is stopped.
- Run the Main VI in the project
- Press OK on the dialog box that appears
- Enter string into string control and press done
Requirements
Software
LabVIEW 2013
LabVIEW 2014
Additional Images or Video
