Overview
This application creates a Sudo Globally Unique Identifier (GUID), which is intended to be a completely unique identifier for use in computer software.
Description
Since computers cannot truly create random numbers, this is accomplished by creating a random number so large that the probability of repeating it is negligible. This VI uses multiple parallel For Loops to create a random set of numbers that are changed into strings and then concatenated into a single GUID string.
The output of this function is a string of the general form {XXXXXXXX-XXXX-XXXX-XXXX-XXXXXXXXXXXX} where X is a single digit hexadecimal number.
Many operating systems, including Windows, implement a GUID generator. However, this function does not utilize operating system calls in order to remain platform independent (ex. Real-Time).
Requirements
Software
LabVIEW 2009 or later
Additional Images or Video
VI Snippet
**This document has been updated to meet the current required format for the NI Code Exchange. For more details visit this discussion thread**
