Description
Description-Separate-1For those who might looking for Cursor Move Event in G Web.
While there is no Choice for Cursor Move under the Graph Control in Event Structure, then here is a workaround I used to sync cursor move between multiple Graph Control On WebVI panel.
below is a Snippet for the Block Diagram:
You may download it (the above image) and drag it to your any blank WebVI block diagram.
Description-Separate-2
