Example Code
Synchronize Analog Readings with Digital Change Events and Record Acquisition Time In a Spreadsheet Using LabVIEW with DAQmx
Products and Environment
    Hardware
  • Data Acquisition (DAQ)
    Software
  • LabVIEW
    Driver
  • NI DAQmx
Code and Documents
Overview
This VI monitors a digital line/digital lines and performs an analog acquisition every time there is a rising or falling edge on those digital lines.
Description
It uses change detection as the sample clock for the digital and analog lines. There is a counter input task that uses a clock to count edges so that the relative time in ms, since the program begins output with each analog sample taken.  The data is recorded in a spreadsheet.
Requirements
  • LabVIEW 2012 (or compatible)
  • NI-DAQmx 12.0
  1. Unzip the attached folder to your computer
  2. Open the VI "Simultaneous Analog and Digital Change Detection 2012 NIVerified"
  3. Ensure all digital and analog signals are connected to the appropriate lines on your device, select the corresponding lines in software and run the program.
Additional Information or References
VI Snippet
Gary P.
