Example Code
Synchronize PXI Time to PCs system with Windows OS
Code and Documents
Overview
Demonstrates how to programmatically synchronize PXI Time to PCs system by calling the SetSystemTIme function from the Windows' kernel32.dll.
Description
First, this program initializes Target, then retrieve hardware handle and Current time and Time zone from the Target. The program defines Format Date/Time. (UTC format specifies if the output string is in Universal Time or in the configured time zone for the computer. ). Then set the date/time to this pc by Call SetSystemTimeFunction from Kernel32.dll.
Requirements
Software:
LabVIEW 2015 (or compatible)
Steps to Execute Code
1. Run LabVIEW as Administrator.
2. Run the program.
3. Select Target.
4. Click the 'Change Time' boolean to change System Time.
5. Click 'Stop' boolean to stop running VI.
Additional Information or References
VI Snippet
Contributors
