Example Code
Synchronize a DAQmx Digital Generation with a Triggered AWG Generation and a Scope Acquisition
Products and Environment
    Hardware
  • Data Acquisition (DAQ)
    Software
  • LabVIEW
    Driver
  • NI DAQmx
Code and Documents
Overview
This example shows how to syhncronize a digital generation using DAQmx with an AWG generation and a Scope acquisition.
Description
The AWG generates a waveform after a digital trigger is detected; the waveform has the first 100 samples set to 0. The AWG exports its sample clock and a marker event on two TTL lines in order to be used by the DAQ board for syncronization purposes.
The DAQ board generates a pattern with the first 100 samples set to 1, so it's easy to verify on the graph that the two generated signals are synchronized.
The Scope acquisition is also syncronized with the AWG generation using NI TClk technology.
Requirements
Software
  • LabVIEW 8.6 or compatible
  • NI-SCOPE 3.4.1 or compatible
  • NI Fgen 2.5.2 or compatible
Hardware
  • NI PXI 5421
  • NI PXI 5122
  • NI PXI 6534
1. Download the Attached VI.
2. Open it with LabVIEW 8.6 or later
3. Choose the desired AWG, Scope, and DAQmx cards
4. Run the VI
Additional Information or References
Andrea N.
Principal Applications Engineer - Semiconductor EMEA
National Instruments Italy
Certified LabVIEW Architect - Certified TestStand Architect
Contributors
