Example Code
Synchronized Analog Output Loopback to Analog Input Using LabVIEW with DAQmx
Products and Environment
    Hardware
  • Data Acquisition (DAQ)
    Software
  • LabVIEW
    Driver
  • NI DAQmx
Code and Documents
Overview
This VI outputs a waveform on an analog output channel and bring the signal back into an analog input channel.
Description
Please note that this requires a physical wire connection between the AO and AI channels, and the user must specify the correct device in the VI.  Also, you must specify the sample clock source of the analog input to be the AO sample clock form the same device, along with having the same rate and number of samples per channel.
Requirements
Software
  • LabVIEW 2012 (or compatible)
Hardware
  • DAQ device with AO and AI channels.
  1. Connect AO and AI channels with a physical wire.
  2. Run the VI, see the synchronized signal waveform in the front panel.
Additional Information or References
VI Snippet
Adam
Academic Product Manager
National Intruments
Comments
David S.
NI Employee (retired)
on
Handy example, but the error handling needs to be reconsidered.
David Staab, CLA
Staff Systems Engineer
enderWiggin10
on
Thanks David.  I have updated accordingly.
Adam
National Intruments
enderWiggin10
on
Adam
National Intruments
enderWiggin10
on
Adam
National Intruments
enderWiggin10
on
Adam
National Intruments
