Overview
This VI shows how to create two Analog Output tasks on two separate devices and use one hardware clock to control both devices.
Description
In this case, we set the rate for Device 0, then export the clock to a RTSI line, but you can also use a PFI line. You can externally connect the RTSI bus or the PFI lines, so the two devices can share a clock.
Note that the slave task must start before the master.
Requirements
Additional Information or References
VI Snippet
