Example Code
Synchronizing Multiple Cursors on Multiple Graphs in LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview:
This code allows the user to Synchronize different Cursors on different graphs.
Description:
A couple of signals (Sine and Sawtooth Waves) are loaded into the Waveform Graphs. There are a couple of loops working in parallel. First one enables Active Cursor, shows Active Cursor and shares the Cursor Index between the Waveform Graphs. The second one does have a Event Structure that handles following events:
Cursor Grab: Register when a user interacts with a graph cursor
Cursor R2 Value Change: Decrement the index of the selected cursor
Cursor L2 Value Change: Increment the index of the selected cursor
Requirements
LabVIEW 2012 (or compatible)
  1. Run the VI
  2. Set Enable the two Available Cursors
  3. Using Left and Right arrows the selected cursor moves through the signals in both Waveforms
Additional Information or References
Comments
Todd S.
NI Employee (retired)
on
Thanks for posting, Corbot.  Do you mind renaming your attachment to include the LabVIEW version?  "_lvXX.vi" would be good enough.
Todd S.
LabVIEW Community Manager
