Overview
This example demonstrates how to synchronize, pause, and continuously acquire data from multiple DAQ device’s by sharing a reference clock, start trigger, and pause trigger.
Description
This example is a modified version of the Multi-Device Synch-Analog Input-Cont Acquisition.vi from the Synchronize Continuous Acquisition of Multiple Analog Input Devices Community Example. Through the manual synchronization method defined in KnowladgeBase 5QJHRL2P , this example shows how to manually route a reference clock and trigger to synchronize multiple devices, when a multi-device task is not supported. This modified example was created as a solution to error -201019 at the DAQmx Start Task.vi, which occurs because the DAQmx Pause Trigger property is not supported by a multi-device task.
Requirements
Software
Hardware
