Overview
The provided example VI shows how you can perform scaling on data using a table of real vs raw values. This is available in LabVIEW with the DAQmx palette but this is usable on an RT target.
Description
Using this VI you should be able to scale your values using a table which allows for non-linear scaling relationships with data.
Requirements
Note: The accuracy defines how much the input signal/scale table needs to be interpolated to allow for array manipulation. The higher the more accurate however there is an exponential increase in CPU requirements.
Additional Information or References
VI Block Diagram
