Overview
This LabVIEW project shows how to implement a temperature monitoring in Labview.
Description
This project is composed by 1 MainVI and three SubVIs. The MainVI implement the temperature monitor while three SubVIs implement respectivily:
The simulated temperature is monitored and charted. If the temperature goes above the "High Limit" that you set the boolean indicator turns on.
Requirements
Additional Information or References
Main VI Block Diagram
