Example Code
Testing Relays in a Matrix Switch Module
Products and Environment
    Hardware
  • Data Acquisition (DAQ)
    Software
  • LabVIEW
    Driver
  • NI DAQmx
Code and Documents
Overview
Demonstrates how to use a DIO capable DAQmx device to test every relay in a matrix switch module.
Description
This example uses a DIO capable DAQmx device, with at least 1 input and 8 outputs, to quickly test every Relay in a Matrix Switch Module.
Requirements
Software:
  1. LabVIEW 2012 (or compatible)
  2. NI-DAQmx
  1. Configure the DAQmx channels and properties to the appropriate values.
  2. Run the Switch Tester. vi.
  3. Click Stop to stop the VI.
Additional Information or References
VI Snippet
Aldo H
Ingenieria de Aplicaciones
