Example Code
Thermocouple calibiration
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
The example shows how to calibirate five thermocouples.The calibration process has to be done by LabView Application.
Description
My Application has to perform the following tasks in sequence
Step 1:  User has to read current calibrator parameters via RS232 and it has to be displayed
Step 2:  User can change the parameter values serialy
Step 3:  Reference temperatures for calibiration should be control
Step 4:  After all the necessary parameters has been set user has to start the calibration
Step 5:  If any necessary parameter has not been set, Then a error message has to popped up and he has to repeat the Step 1 & 2
Step 6:  Start Calibiration
Step 7:  Bath has to be set for all reference temperature and the stailized Thermocouple reading from ni 9213 for the known temperature has to be logged in .csv file.
Step 8:  User should have a control to stop Calibiration in Middle.
Requirements
Software:
  1. LabVIEW 2012
  1. Unzip the attached folder to your computer
  2. Open the VI "Calibrator 2012 NIVerified.vi"
  3. Run the program
Additional Information or References
VI Snippet
Comments
MHECM
Member
Member
on
Thanks for sharing the program. When I run it, it asks for the file "calibratorsettings.ctl". Where can I find it?
