Example Code
Threshold RGB Original Color Image using the NI Vision Development Module and LabVIEW
Products and Environment
    Software
  • Vision Development Module
  • LabVIEW
Code and Documents
Overview
This VI demonstrates how to threshold a color image on defined RGB values.
Description
This VI overlays a cross hair on an image and determine the distance to the center of a circle. In this example, the crosshair location can be specified by the user by selecting the location on the example image or by changing the coordinates of the cross hair. The distance from the cross hair to the center of a circle is displayed.
An example without the NI Vision Development Module can be found on the following link:
http://forums.ni.com/t5/Example-Programs/Scale-Color-Panes-from-a-Color-Image-without-using-the-NI-V...
Requirements
 Software
  • LabVIEW Base Development System 2012 (or compatible)
  • NI Vision Development Module 2012 (or compatible)
  • If running in a Real-Time context, you will need the LabVIEW Real-Time Module 2012 (or compatible)
 Hardware
  • No hardware is necessary to use this example VI
  1. Download and open the attached ZIP-file
  2. Open the VI and follow the instructions inside
Additional Information or References
 Threshold RGB on Color Image LV2012 NIVerified.vi - Front Panel.pngThreshold RGB on Color Image LV2012 NIVerified.vi - Front Panel.png
Threshold RGB on Color Image LV2012 NIVerified.vi - Block Diagram.pngThreshold RGB on Color Image LV2012 NIVerified.vi - Block Diagram.png
 **The code for this example has been edited to meet the new Community Example Style Guidelines. The edited copy is marked with the text ‘NIVerified’. Read here for more information about the new Example Guidelines and Community Platform.**
Paolo F.
