Example Code
To Do List - LabVIEW
Code and Documents
Overview
This VI is a very simple to do list program.
Description
This example demonstrates how to program a to-do-list in LabVIEW. The list can record all the tasks and display the uncompleted tasks. When you finish a task, click the status button, and the corresponding task will be marked as completed and be concealed immediately.
Requirements
LabVIEW 2013 (or later)
  1. Download the correct version of the VI for your system
  2. Run List.vi
  3. Type tasks into the rows
  4. When a task is completed, click the green button to the left of it and it will be removed from the list
  5. lose the VI to stop execution. The remaining tasks are saved to the text file and will reappear the next time the VI runs.
Comments
crossrulz
Knight of NI Knight of NI
Knight of NI
on
Some comments:
  1. Your While loop never ends.  You need to have the Panel Close event case pass a TRUE to the Conditional terminal.
  2. You don't need the timeout for the Event Structure.  Remove the timeout case as well.
  3. I recommend NOT using property nodes to update your items list.  Use a local variable instead.  They are A LOT for efficient.
