Example Code
Toggle Digital Output at Random Intervals
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
Software based random toggle time for a Digital Output line.
Description
This VI uses the random number generator to map the random values between 0 and 1 to an interval between 3 and 5 seconds. This random time is used with the Wait (ms) function to toggle a digital output with random software timing.
Requirements
1. LabVIEW 2012 or compatible
2. NI DAQmx compatible version
1. Specify the output line for the Digital Output Task.
2. Select the Run button.
Additional Information or References
Comments
Todd S.
NI Employee (retired)
on
Thanks for posting!  Please rename your attachment to include the LabVIEW version ("_lvXX.vi" would be fine).
Todd S.
LabVIEW Community Manager
