Description
Description-Separate-1This example shows you how to control Tree table with user dialog box in DIAdem. Use the Tree object to define a tree to be displayed in the dialog box. This example creates the tree contents in the script. The contents change displayed data dynamically in a different event. If you click a node, the example displays the entry you clicked.
The functions of this example are as follows:
- The Xtable shows channel data, depending on the tree item selected in the channel list.
- According to the results retrieved from Channel name search, the tree items in the Channel list are filtered.
Description-Separate-2How to Use
How-Separate-1
- Open the SCRIPT tab of the DIAdem, and press the button create user dialog box function.
- Run the attached Dlg_Tree_Example.SUD from the DIAdem DIalog Editor. (Or double-click the SUD file to launch the Editor.)
- Press the Test in DIAdem button to launch Dialog from DIAdem.
The tee example display below :
How-Separate-2Related Links
Related-Separate-1Related-Separate-2
