Overview
The example is to demonstrate the flow of generating a triangular signal and then acquiring it with the analog output and record it with a measurement file.
Description:
The VI would independently generate
Steps to Implement or Execute Code:
To implement this example:
To execute this example:
Requirements
Software
LabVIEW 2012 or compatible
NI-DAQmx 9.0 or compatible
Hardware
cDAQ with C series Counter Output Module
