Example Code
Triggered Data Recording with DIAdem DAC
Code and Documents
Overview
In certain cases, a "selective" data measuring is desired in order to save memory resources. This funcionality is provided by this DAC diagram.
Screenshot from the Visual in "Recording" stateScreenshot from the Visual in "Recording" state
Description
  • A function generator produces a sine.
  • We only want to record data when the value > 1.
  • If the window with undesired values [-10 ... 1] is entered, a trigger stops the data saving and hides the F1 car.
  • The Not operator inverts this trigger, starts the data saving and shows the F1 car.
Hardware and Software Requirements
DIAdem Base 2012 SP2 with DAC Kit (or compatible)
1. Open Triggered Data Recording - DIA2012SP2.DAC
2. Start a measurement
Additional Information or References
Eric H.
Applications Engineering
Contributors
