Example Code
Tristate Button Control
Code and Documents
Here is a simple example of a customized picture ring that is made to work like a tristate button control. The increment button of the ring is made to extend over the entire area of the picture & the button is made transparent. Now any clicking will be on the increment button.
This can be extended to any number of states.
Comments
JockeR
Member
Member
on
This is exactly what I was looking for. But how do you change the colors?
Priyadarsini
Member
Member
on
Hi JockeR,
The control is a picture ring - each item is a picture filled with the needed color - here there are 3 pictures with colors red, green and black. Clicking on the control is like clicking on its increment button (you can use the Advanced>>Customize window to see the overlay) and the pictures are traversed in order.
testdesign
Member
Member
on
This is really good information Priyadarsini.  The thing I can't get is when I put down an Enum Picture Ring on the front panel I am unable to customize it.  Which enum pict control are you using?  Silver, Classic, or Modern enum pict control?
Also, when clicking on the picture how do you customize the enum picture control to work as if you were clicking on the increment button?
Thanks so much!
TeraTech
Member
Member
on
Nice but lacks clarity when using it as to the purpose of each color.  I guess you could add some labels? But don't like that the user has to click through one state to get to another state. Could be bad depending on the code behind it. Also, I couldn't figure out how to edit the colors from the customize menu. I like this one
https://forums.ni.com/t5/LabVIEW/Front-panel-control-with-3-states/m-p/3580050/highlight/true#M10023...
Contributors
