Example Code
Two Different Flowrates and Resulting Concentration Example using LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
If we have two different flow rates and a known concentration we want to achieve, how long should each valve be open to get the right concentration?
Description
To know how long we need each valve open for, we need to know the flowrates of each valve (In the same units!) and the desired concentration (e.g. %50 fluid A). The formula in this VI uses those 3 pieces of information to find out the ratio of time for each valve and if you input the total time you want to run the valves, will give the amount of time (in seconds) for each valve!
Requirements
LabVIEW 2012 (or compatible)
  1. Open the VI
  2. Input the flow rates and desired concentration
  3. Optional Input: The total time of mixing
  4. Run the VI
  5. Observe the resulting ratio for fluid A
  6. Observe the resulting time for each fluid to run if you input a time target
Additional Images
Block Diagram
Contributors
