Example Code
USB DETECT AND PERFORM READ WRITE TEST
Products and Environment
    Software
  • LabVIEW
  • Other
Code and Documents
Overview
A demonstration of detecting and trimming drive name and then read/write test on that drive.
Description
USB Test is the main VI which can be used to detect your USB Drive and trim its Name. Also, it performs read write test on that drive. Get Drive Name is a SubVI that gets certain drive’s name.
Requirements to Run
  1. LabVIEW 2012 (or compatible)
  2. OpenG library
  1. Specify an expected drive name
  2. Run the program.
Additional Information or References
VI Snippet
Comments
zorandinho
Member
Member
on
Sub vi's are missing.
MangeshD
Active Participant
Active Participant
on
Zorandinho,
The Sub VI's which are missing may be you don't have an OpenG toolkit downloaded in your Labview.
Please Download it from VIPM. I have used OpenG Tools inside the above Code
