Overview
 This example VI shows how to use the USB Interrupt Pipe utilizing LabVIEW VISA commands.
 Description
This example VI shows how to use the USB Interrupt Pipe utilizing LabVIEW VISA commands. You must have a VISA Driver for your device and the RAW USB device must show up in Measurement and Automation Explorer. The example VI will then be able to work if the device supports an Interrupt Pipe.
Requirements
Software
Hardware
NOTE: You must first get your interrupt pipe USB device recognized by Windows and attach VISA to it as a driver using the VISA Driver Development Wizard. The USB RAW name should show up in MAX, and you should be able to select it below. Running this VI will cause the VI to wait for an interrupt from the device and then return the interrupt data once it occurs.
Additional Information or References
VI Snippet
