Overview
These VIs illustrates control in and control out functions to a USB RAW device as results of user events.
Description
It is designed to only work with USB RAW devices. For example, to get the status of a particular device, you could use the following values in a Control In function:
Request Type: 0x80 (Device to Host, Standard Type, Device Recipient)
Request: 0x00 (GET_STATUS)
Value: 0x00
Index: 0x00
Length: 0x02
Requirements
Software:
Labview 2012 (or compatible)
Hardware:
USB RAW device
1. Ensure USB RAW device is normally connected
2. Run the VI
Additional Information or References
NOTE: All controls above are configured to accept a HEXADECIMAL input. This can be changed to accept decimal values by changing the Format and Representation for each control.
The last two bits of the value returned will let you know whether the device is set to remotely wake up (bit 1), and whether the device is self powered (bit 0).
To perform control transfers with another device, close the session to the current device, select another device from the VISA resource name control, and open a session to it.
When complete, press the Stop button to end execution.
Dan King
