Example Code
Unit Conversion - Meters to Feet
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
Conversion from meters to feet and inches.
Description
This code obtains values in meters and generates the conversion to feet and inches. Not only it displays the feet and inches calculations separately, but it will also prompt a string with the used conversion.
Requirements
LabVIEW 2012 (or compatible)
1. Insert the values in meters that you would like to convert.
2. Select the Run button.
Additional Information or References
Dan King
