Description
Description-Separate-1This article covers implementation of Serial Synchronous Interface (SSI) with NI products, using an FPGA board with digital lines and programming the protocol in FPGA.
Description-Separate-2How to Use
How-Separate-1NI provides the NI-6584 Digital I/O Adapter Module for FlexRIO, which is designed for interfacing with RS-422 or RS-485 serial communications standards. Be sure to use it with a compatible FlexRIO device.
You can download a simple example from the attachments.
How-Separate-2
