Overview
This example is a modification of a shipped example that synchronizes each particular frame instead of the acquisition's start for two boards.
Description
The "HL Grab with Two Boards.VI" shipped example uses the NI Vision Acquisition Software to synchronize the start of an acquisition in two different frame grabber boards.
By exporting the Frame Start signal from one camera to the Trigger Each Buffer trigger configuration of the other camera, the first one effectively becomes a Master while the second a Slave. The master triggers the slave when it starts to grab a frame. In order to achieve this, the boards need to be connected with a RTSI line.
Requirements
Software
LabVIEW 8.5 "or compatible"
Vision Acquisition Software 8.5 "or compatible"
Hardware
Since the trigger is exported over the RTSI line, this setup requires a RTSI cable between the master board and the slave board.
Additional Information or References
VI Snippet
**This document has been updated to meet the current required format for the NI Code Exchange. For more details visit this discussion thread**
Thanks for posting! Could you add a picture of the code to give us an idea what it looks like before we download?
