Example Code
Use Internet Explorer 11 as Webbrowser on a LabVIEW UI
Products and Environment
    Programming Language
  • LabVIEW G
Code and Documents
Description
LabVIEW provides a WebBrowser control. It is a .NET control that contains an embedded Internet Explorer control. An example is provided here: https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000YKVvCAO&l=fr-CH
But infortunately, when a WebBrowser is called, Internet Explorer use Internet Explorer 7 engine to render the website. This is not usable to display a modern Website with HTML5 stuff.
To render correctly a modern Website, we have to coerce Internet Explorer to use Internet Explorer 11 engine. It is possible to do that using Windows registers. This example modifies HK_Current_User. To Enable IE11 mode, we have to write the application name (.exe file) in HKEY_CURRENT_USER\SOFTWARE\Microsoft\Internet Explorer\Main\FeatureControl\FEATURE_BROWSER_EMULATION. In developement mode, it will be Labview.exe.
More informations from Microsoft here : https://docs.microsoft.com/en-us/previous-versions/windows/internet-explorer/ie-developer/general-in...
This example VI writes in register. You have to restart once to take effect.
Without Internet Explorer 11 emulation (IE7):
With Internet Explorer 11 emulation :
How to Use
Comments
Desruelle_luc
Trusted Enthusiast Trusted Enthusiast
Trusted Enthusiast
on
Bravo.
Tu as raison. C'est un super partage, comme souvent.
Tu ne penses pas qu'il serait "temps" que NI migre l'objet container .NET de LabVIEW vers -> update the embedded web browser in order to comply with HTML5 ? : Modern embedded web browser
cf un échange récent
Résolu : Modern embedded web browser - NI Community
A bientôt
A+
Luc
Luc Desruelle | Mon profil | Mon blog LabVIEW |
LabVIEW Architect (CLA) & TestStand Developper (CTD) | LabVIEW Champion
MESULOG | NERYS
Contributors
