Contactless Test Station III (CTSIII) is able to emulate a Near Field Communication (NFC) listening device and communicate with a device acting as an NFC polling device such as:
- Point of sale reader (Payment reader)
- Commercial On the Shelf (COTS) mobile payment device
- Access control reader
- NFC car handle
In card emulation mode, CTSIII supports common NFC communication protocols such as:
- ISO 14443 Type A (106 to 848 kbits/s)
- ISO 14443 Type B (106 to 848 kbits/s)
- ISO 15693 Vicinity (low and high data rate)
- ISO 18092 NFC-IP1 (Type A 106 kb/s, FeliCa 212 and 424 kb/s)
End-user may want to build test scenarios and analyze the communication between CTSIII and a device acting as an NFC Reader for several reasons:
- build simple communication script and analyze device under test commands
- for design and characterization tests
- build a script and test it within MPManager before implementing a test application to do the same or more thanks to MPuLib communication dll and libraries
- perform specific measurements or tests and compare the results with ISO, EMVCo or NFC Forum test specifications.
In this example, a Type B card emulation sequence will be used to communicate with an NFC Reader.
CTSIII includes a card emulation sequencer, which will sequentially execute a list of actions.
Compare to a high-level script where there are back and forth communications between the computer on which one MPManager is running and the CTSIII controlled by the same computer, the CTSIII sequencer generates an embedded application containing the scenario to execute.
This allows very tight timings control.
For example, the end-user can fully control the FDT PCD to PICC (Frame Delay Time - Proximity Coupling Device - Proximity Integrated Circuit Card).
In type B, this timing is defined as TR0+TR1.
TR0+TR1 is the time between the rising edge of the End Of Frame (EOF) of the last Proximity Coupling Device (PCD) command and the falling edge of the Start Of Frame (SOF) of the next Proximity Integrated Circuit Card (PICC) answer.
TR0+TR1 can be measured as follow:
The end-user can also control some other Type B timings such as:
- extra guard time duration
- End Of Frame duration
- Start of frame low and high durations
Description-Separate-2CTSIII is delivered with an NFC simulation antenna (P/N 786703-01).
The antenna is used to perform continuous and successive exchanges with an NFC device, using either MPManager scripting and test functions or a user program.
Perform the following connections between the antenna and CTSIII:
| Antenna connector | CTS3 connector |
| TCL3 HDMI | AUX 1 HDMI |
| Analog In SMA | ANALOG IN SMA, using the provided SMA low-pass filter (P/N 773919-01) if configured in 50 Ω |
| Tx/Rx SMA | TX/RX SMA |
Download the Card_Emulation_sequencer_TypeB script and video in the attachment.
Power on CTSIII and open MPManager 3.9.0 (or above).
Position the PICC-PCD simulation antenna on top of the antenna of the NFC reader to communicate with.
Connect the CTSIII and like in the video, open the Card_Emulation_sequencer_TypeB script in the script editor of MPManager UI
and execute the script.
End-user has access to the execution log of the sequencer script where the success of the execution of the sequence can be checked.
Note that the card emulation sequence is pre-compiled before being executed to avoid compilation delay.
The time TR0+TR1, between the rising edge of the End Of Frame (EOF) of the last Proximity Coupling Device (PCD) command and the falling edge of the Start Of Frame (SOF) of the next Proximity Integrated Circuit Card (PICC) answer, is programmable and applied with high accuracy.
In the viewer tab of MPManager, the end-user gets access to the *.mplog trace and can navigate through it to analyze the communication
between the Reader under test and the lower tester (CTSIII).
Note that NI proposes a large range of automatized conformance test solutions that are certified for EMVCo or NFC Forum testing, on top of CTSIII.
Especially, EMVCo or NFC Forum digital test solutions for polling devices include thousands of tests that have been implemented with the card emulation sequencer.
How-Separate-2For any additional questions, please contact NI technical support team on NI.com when opening a Service Request case using the NI Service Request Manager (SRM).
To open a service request on NI.com please follow the steps described at this link.
https://micropross.ni.com/webinars/contactless-test-station-3-external-webinar/
Related-Separate-2Example code from the Example Code Exchange in the NI Community is licensed with the MIT license.
