This example demonstrates how to generates a 3-phase voltage (sine waves 120 degrees apart) using three analog output (AO) channels with NI-DAQmx with support for LabVIEW NXG for Data Acquisition Hardware.
This example generates a 3-phase voltage using three analog output channels. A three-phase voltage consists of three sine waves, each 120 degrees apart in phase, each representing a separate voltage varying over time.
Hardware:
A device with three analog output channels is required, such as a 671x data acquisition (DAQ) device.
Software:
LabVIEW NXG 1.0 or compatible
DAQmx 17.0 or compatible
1.Connect the three designated output channels to the inputs of a three-phase device.
2. Configure the software to map to the analog output channels that you are using.
3. Enter the frequency (Hz) of the output sine wave, and the amplitude of each phase voltage.
4. Run the VI.
