Overview
This example demonstrates how to allocate .NET memory in order to initialize an array of strings to a set of values.
Description
CVI provides an API to create and use .NET objects within the C environment. This example demonstrates how to allocate .NET memory in order to initialize an array of strings to a set of values.
Requirements
Additional Information or References
C code
#include <cvidotnet.h>
#include <ansi_c.h>
void CreateDotNetArray (void);
/// HIFN The main entry-point function.
/// HIPAR argc/The number of command-line arguments.
/// HIPAR argc/This number includes the name of the command-line tool.
/// HIPAR argv/An array of command-line arguments.
/// HIPAR argv/Element 0 contains the name of the command-line tool.
/// HIRET Returns 0 if successful.
int main (int argc, char *argv[])
CreateDotNetArray();
return 0;
//Create .NET array of Strings and read them back to be displayed
int i = 0;
char *pChannelsList[3] = {0};
int lookupIndex = 0;
//The length of the list. This parameter will be passed to the CDotNetCreateArray function
ssize_t iChannelLength = 3;
CDotNetHandle dotNetArray = 0;
//Variables that will hold the strings as they are read back
char *stringEle0 = "";
char *stringEle1 = "";
char *stringEle2 = "";
//Allocate the DotNet memory for strings
for (i=0; i<3; i++) {
pChannelsList[i] = CDotNetAllocateMemory(250 * (sizeof(char)));
//Provide a list of strings
strcpy(pChannelsList[0],"This is test string #1");
strcpy(pChannelsList[1],"This is test string #2");
strcpy(pChannelsList[2],"This is test string #3");
//numberOfDimensions: dims in the array to be created. 1 in our case
//lowerBounds: array of lower bounds of each dimension. 0 is the default
//lengths: a pointer to an array of lengths for the dimensions. This is NOT the memory length, simply the number of elements in each dimension.
// in our case this is the length of our string array which is 3, initialized above
//array: a reference to the .NET array handle
CDotNetCreateArray(CDOTNET_STRING, 1, 0, &iChannelLength, pChannelsList, &dotNetArray);
//Retrieve the elements from the array to display them
CDotNetGetArrayElement(dotNetArray, CDOTNET_STRING, 1, &lookupIndex, &stringEle0);
lookupIndex++;
CDotNetGetArrayElement(dotNetArray, CDOTNET_STRING, 1, &lookupIndex, &stringEle1);
lookupIndex++;
CDotNetGetArrayElement(dotNetArray, CDOTNET_STRING, 1, &lookupIndex, &stringEle2);
//Display the elements
printf("%s\n%s\n%s", stringEle0, stringEle1, stringEle2);
//Free the DotNet memory
for (i=0; i < 3; i++) {
CDotNetFreeMemory(pChannelsList[i]);
printf("\n\nPress Enter to Exit");
//Display output before exiting
getchar();
