Example Code
Using LabWindows/CVI Code Module Enumerated Values in TestStand
Products and Environment
    Software
  • LabWindows/CVI
  • Teststand
Code and Documents
Description
Overview
This example demonstrates how to define an enumeration in a CVI DLL that can be detected in the parameters pane in a calling Step in TestStand.
Description
To Create an enumeration in a CVI DLL, it is necessary to define a function panel (fp) for the enum variable.  Instructions for completing this can be found here:
KnowledgeBase: TestStand and LabWindows/CVI Enumeration Data Types
After implementing these steps, the parameter pane will show a dropdown for the enum parameter
Hardware and Software Requirements
CVI Enumerated Values - TS2014.zip
TestStand 2014 or compatible
LabWindows/CVI 2012 or compatible
  1. Open the attached example sequence file, and select the DLL call step
  2. Observe that the enum parameter provides a drop-down in the parameters pane
Al B.
Staff Software Engineer - TestStand
CTA/CLD
