Example Code
Using OpenG Toolkit for 2D Array Operations In LabVIEW
Products and Environment
    Software
  • LabVIEW
    Driver
  • Other
Code and Documents
Overview
This code shows how the OpenG Toolkit allows you to sort a 2D array using the modified
Description
After generating a 2D array of random values, this VI sorts the array based on a column or row specified by the user.
Requirements
  • LabVIEW 2013 (or compatible)
  • OpenG Toolkit
  1. Download the attached VI.
  2. Set the inputs to generate a 2D array with the desired sorting options
  3. Run 2D Array Sort OpenG 2013 NIVerified.vi
  4. Modify code to allow for sorting of your own 2D array.
Additional Information or References
VI Block Diagram
**This document has been updated to meet the current required format for the NI Code Exchange. **
