Example Code
Using State Machine to Determine Warnings
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
Coding that exemplifies how to use a state machine architecture to verify some climate conditions.
Description
This VI is intended as an example on how to use the state machine architecture to check different conditions and report them to the user. In it, we enter the current temp, current wind speed, max temp, min temp, and max wind speed in order to have the program output a string corresponding with the current conditions.
Requirements
LabVIEW 2012 (or compatible)
1. Set the parameters for Minimum, Maximum, and Current Temperature.
2. Set the parameters for Maximum, and Current Wind Speed.
3. Select the Run arrow.
Additional Information or References
Justin Parker
Product Support Engineer
