Example Code
Using TestStand Users to Restrict Access to Certain Test Sequences from a LabVIEW UI
Products and Environment
    Software
  • Teststand
Code and Documents
Description
Overview
This example shows how to check for specific permissions before running the rest of a sequence.  This can be useful to prevent certain users from unintentionally running diagnostic or debugging code.
Description
You may want to restrict which users have permission to run certain sequence files, for example, you may want to prevent an operator user from running a calibration routine.  To accomplish this, you can use the TestStand API to check whether the current user has a specific permission:
RunState.Engine.CurrentUser.HasPrivilege("Debug")
In this example, if this method returns false, the sequence file terminates and reports to the user that the sequence requires specific permissions to execute.
Hardware and Software Requirements
Require Privileges To Execute - TS2012.seq
TestStand 2012 or Compatible
  1. Open and run the attached example using Execute » Run MainSequence.
  2. Observe that the example executes with no issues.
  3. In the user manager, create an operator user with only the Operate privileges.
  4. Log out of TestStand and log in with the new user.
  5. Open the sequence file again and run it.  Observe that a message is shown indicating that the "Debug" privilege is required, and the example terminates.
Additional Information or References
Aldo H
Ingenieria de Aplicaciones
