Overview
The VI Server is a very powerful tool and there are several ways and purposes you can use it for.
This is an example about how to use the VI Server to enqueue an element on a queue, that resides on a HOST PC, from a controller PXI RealTime.
Description
The VI Server provides different instances and if you do not interrogate the right one the PXI RT will not be able to recognize the queue reference that already exists on the HOST PC.
The code provided by this example has been developed to resolve an issue that a customer faced.
The queue is used to host data on the HOST PC and it's monitored by a Main application that waits data to process (data hosted by the queue could be any kind of data type).
A "bridge" VI is used to obtain the reference of the existing queue (on the HOST PC) and to enqueue an element. The "bridge" VI is called from the PXI RT through the VI Server, but it's executed on the HOST PC.
Requirements
Software
LabVIEW 2013
LabVIEW Real Time Module 2013
Hardware
PC with LV 2013 installed
Controller PXI RealTime (doesn't matter the model)
Additional Images or Video
